Ir para o conteúdo principal
Huawei M750 Back Panel Replacement
O que você precisa
  1. Huawei M750 Back Panel Replacement, Battery: passo 1, imagem 1 %32
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Huawei M750 Back Panel Replacement: passo 2, imagem 1 %32
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Huawei M750 Back Panel Replacement, Back Panel: passo 3, imagem 1 %32
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Huawei M750 Back Panel Replacement: passo 4, imagem 1 %32 Huawei M750 Back Panel Replacement: passo 4, imagem 2 %32
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Huawei M750 Back Panel Replacement: passo 5, imagem 1 %32 Huawei M750 Back Panel Replacement: passo 5, imagem 2 %32
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 224
