Introdução
Use this guide to replace a faulty touchscreen.
The touchscreen is the layer of the tablet that houses the accelerometer using multiple sensors and lies beneath the glass. After taking apart the tablet, all you need to do is separate the LCD from the touchscreen.
O que você precisa
Place the tablet on a flat clear surface to keep the screen safe.
Slide the larger portion of the back cover off the tablet.
This will reveal the battery.
Using a plastic opening tool, pry off the top cover casing gently by moving the tool along all three sides.
Tilt the tablet on its lengthy side, place your thumbs on the side and gently separate the LCD from the touchscreen.
