O que você precisa
Heat the parts marked in red on the back side of the phone with a hair dryer or heat gun.
Attention: The sides have to be hot, not scalding.
Insert the iSesamo delicatley between the two sides (see photo)
Once the iSesamo is inserted, slide it along the sides to remove the adhesive.
ATTENTION: DO NOT SLIDE THE ISESEMO ALONG THE PART MARKED IN GREEN.
Remove the screw on the metal plate which protects the fingerprint sensor cable
Remove the the fingerprint censor cable using a plastic spudger.
Remove the 16 screws with a Phillips screwdriver.
Using the iSesamo, remove the protection from the motherboard
Remove the 2 tabs marked in red.
Gently remove the battery with a playing card or bank card.
Peel off the connector on the screen.
Heat the contours of the screen as shown in Step 1.
insert the iSesamo between the screen and the chassis
Be sure to pass the iSesamo under the white plate of the screen (see photo)
Go around the phone.
Note that the operation can be more complicated depending on the level of the screen.
Glue the screen on the frame by passing the sheet through the hole provided for this purpose
To reassemble your device, follow the instructions in reverse order :)
4 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
4 comentários
Est-ce que quelqu'un a essayer ? a combien estimez vous la réparation: ecran + accessoires ? Car le lien ne fonctionne pas. En tout cas tuto très bien réalisé ;)
Moi forcement ...
Chez moi le lien fonctionne, la pièce est à 55,99€, tu peux demander des accessoires gratuit
Sinon merci ;)
Bonjour
Merci pour ce tuto. J'aurais juste une question.
Comment recollé la vitre arrière après la réparation ?
J'ai déjà eu le cas sur un smartphone Sony et je n'ai pas réussi à correctement recollé la face arrière.
Merci a bientôt
