Introdução
Use this guide to replace the fingerprint scanner assembly on your device. This requires the use of a heat gun to weaken adhesive, be safety cautious when using these tools.
O que você precisa
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Disconnect the fingerprint scanner cable attached to the motherboard using a spudger or your finger.
5 outras pessoas executaram este guia.
