Introdução
Use this guide to remove or replace the rear glass in the Huawei Honor 10.
You’ll need replacement adhesive to reattach components when reassembling the device.
Ferramentas
Peças
Nenhum componente especificado.
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Uma outra pessoa concluiu este guia.
