Introdução
Use this guide to remove and replace broken or defective rear cameras in the Huawei Honor 10.
You’ll need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
Remove the foil completely.
Remove the six Phillips screws securing the motherboard cover:
Four 3.4 mm long screws
Two 2.9 mm long screws
Use the flat end of a spudger to pry up and disconnect the flex cable for the rear cameras.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
