Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Place the phone screen down on a flat surface.  Underneath the camera there will be a indentation, place your thumb or pointer finger on the indentation and pull gently up towards you. The back of the phone should pop off easily.
    • Place the phone screen down on a flat surface. Underneath the camera there will be a indentation, place your thumb or pointer finger on the indentation and pull gently up towards you. The back of the phone should pop off easily.
  2. Underneath the back of the phone you will find the battery. The battery is located in the middle of the phone's inner backing.   By the battery you will find a similar indentation;  place your thumb in the indentation and lift the battery towards you. The battery will come right out. Underneath the back of the phone you will find the battery. The battery is located in the middle of the phone's inner backing.   By the battery you will find a similar indentation;  place your thumb in the indentation and lift the battery towards you. The battery will come right out.
    • Underneath the back of the phone you will find the battery. The battery is located in the middle of the phone's inner backing. By the battery you will find a similar indentation; place your thumb in the indentation and lift the battery towards you. The battery will come right out.
  3. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Along the edges of the phone you will find 8 screws, to remove these screws use a screwdriver( T5 if you are using the screwdriver  found in the ifixit 54 bit driver kit) Take the screws out by twisting left and set them in a spot where you will not lose them. Take the screws out by twisting left and set them in a spot where you will not lose them.
    • Along the edges of the phone you will find 8 screws, to remove these screws use a screwdriver( T5 if you are using the screwdriver found in the ifixit 54 bit driver kit)
    • Take the screws out by twisting left and set them in a spot where you will not lose them.
  5. Use the blue plastic opening tool by sliding it along the edges of the phone to pull back the frame. Use the blue plastic opening tool by sliding it along the edges of the phone to pull back the frame.
    • Use the blue plastic opening tool by sliding it along the edges of the phone to pull back the frame.
  6. After removing the phone's frame, you will see the camera placed in a metallic cube, to remove the cube lift the edge gently and pull to the left. You will notice the cube is attached to a copper ribbon, do not separate the cube from the ribbon!! it is attached.
    • After removing the phone's frame, you will see the camera placed in a metallic cube, to remove the cube lift the edge gently and pull to the left.
    • You will notice the cube is attached to a copper ribbon, do not separate the cube from the ribbon!! it is attached.
  7. CONGRATULATIONS!!! you have successfully completed this guide, please share this guide with your friends
    • CONGRATULATIONS!!! you have successfully completed this guide, please share this guide with your friends
    • Yay! Party time don't forget the bean dip
Conclusão
Julie Vasquez
Membro desde: 30-11-2017
133 reputação
Autoria de 1 guia
Very specific and thorough. Wonderful job ladies!
Dan Hartzell - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 215
