Introdução
It is a fairly simple and straightforward guide. Just be gentle when you're removing the parts. They can break easily.
O que você precisa
Flip the device over so that the back of the phone is facing you and the screen is against your palm.
Locate the slit at the bottom of the back cover.
Using your fingernail, lift up on the back cover to expose the battery.
Find the indented notch at the base of the battery.
Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
After removing the battery, remove the screws using a T6 screwdriver.
There are eleven screws that hold the middle cover to the rest of the phone.
The screw that is marked by the orange circle is covered by a white dot.
After all the screws are removed, use your fingers to remove the lower section of the middle cover.
Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath.
Begin working your way around the sides of the cover plate, unsnapping it gently.
The middle cover is a thin piece of plastic with the external speaker inside of it.
The antenna is a thin white wire that connects to the circuit board in two locations.
Lift gently at each connector of the white wire to disconnect the antenna from the port.
