Ir para o conteúdo principal
Huawei Ascend P6-U06 Battery Replacement
O que você precisa
  1. Huawei Ascend P6-U06 Battery Replacement, SIM  Card: passo 1, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement, SIM  Card: passo 1, imagem 2 %32
    • Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
  2. Huawei Ascend P6-U06 Battery Replacement: passo 2, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement: passo 2, imagem 2 %32
    • Insert the pin into the SIM card opening located on the right-side of the phone.
    • Gently push in until the SIM card clicks, and then pull the pin and SIM card out.
    • Repeat this process for the additional SIM card.
  3. Huawei Ascend P6-U06 Battery Replacement, Back Panel: passo 3, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement, Back Panel: passo 3, imagem 2 %32
    • Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
    • You may need a sharp thin object to get underneath the plastic.
  4. Huawei Ascend P6-U06 Battery Replacement: passo 4, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement: passo 4, imagem 2 %32
    • Rotate the phone 180 degrees so that the bottom of the phone is now facing up.
    • Firmly push up on the back panel with your thumbs.
    • Lift up the back panel from the top right corner and gently pull it away from the phone.
  5. Huawei Ascend P6-U06 Battery Replacement, Battery: passo 5, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement, Battery: passo 5, imagem 2 %32 Huawei Ascend P6-U06 Battery Replacement, Battery: passo 5, imagem 3 %32
    • Remove the following screws securing the logic board to the main frame:
    • Five 2mm Phillips #000 screws
    • Two 2.5mm Phillips #000 screws
  6. Huawei Ascend P6-U06 Battery Replacement: passo 6, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement: passo 6, imagem 2 %32
    • Push down the yellow plastic lining at the top of the battery and remove the two 2.5mm Phillips #000 screws.
  7. Huawei Ascend P6-U06 Battery Replacement: passo 7, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement: passo 7, imagem 2 %32 Huawei Ascend P6-U06 Battery Replacement: passo 7, imagem 3 %32
    • Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate.
    • Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate.
    • Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
  8. Huawei Ascend P6-U06 Battery Replacement: passo 8, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement: passo 8, imagem 2 %32 Huawei Ascend P6-U06 Battery Replacement: passo 8, imagem 3 %32
    • Use the pointy end of a spudger to pry the antenna connector off of its socket.
    • Upon reassembly, you will hear a "click" that indicates the pin has been properly reconnected.
  9. Huawei Ascend P6-U06 Battery Replacement: passo 9, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement: passo 9, imagem 2 %32 Huawei Ascend P6-U06 Battery Replacement: passo 9, imagem 3 %32
    • Use the pointy end of a spudger to gently pry the following connectors out of their sockets:
    • silver LCD cable connector
    • silver Headphone jack cable connector
  10. Huawei Ascend P6-U06 Battery Replacement: passo 10, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement: passo 10, imagem 2 %32 Huawei Ascend P6-U06 Battery Replacement: passo 10, imagem 3 %32
    • Use the pointy end of a spudger to gently pry the following connectors out of their sockets.
    • Sliver Micro-USB cable connector
    • Copper battery cable connector
  11. Huawei Ascend P6-U06 Battery Replacement: passo 11, imagem 1 %32 Huawei Ascend P6-U06 Battery Replacement: passo 11, imagem 2 %32
    • Be careful not to bend, puncture, or crush the battery, even if it is being replaced. The battery can potentially release toxic and flammable chemicals.
    • Use a plastic opening tool to gently lift up the battery from the bottom end.
    • You may need to loosen the adhesive under the battery with slow sawing motions.
Conclusão
24 outras pessoas executaram este guia.
Chase Hemming
Membro desde: 10/14/14
2.623 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 4-44, Amido Fall 2014 Membro de Cal Poly, Team 4-44, Amido Fall 2014
CPSU-AMIDO-F14S4G44
Membros da 5
Autoria de 11 guias
10 comentários
Thanks! Easy to understand, I needed about 30 Minutes...
Max - Responder
what is the purpose of step 9?
Nicolas - Responder
Great instructions. I tried it and it worked.
A few additions: when removing the first piece, I couldn't find a purpose in squeezing the main section. On opening it, I found the small black section you first have to remove has tiny plastic clips at each of the four corners, so maybe pressing the main section of the back in the middle helps tilt the back section so that the bottom of the back section is raised up ever so slightly to help release the tiny plastic clips on the first piece.
I suggest when you have prized off a piece, (the electronic connnections, not the phone back cover) try putting it back again immediately and taking it off again. This helps you know if it is going OK when you finally put it back again.
See next post
Ricky Man - Responder
I found there some of the screws and pieces to prize off that I couldn't see why they needed to be undone, but hey, it worked fine.
When it comes to taking the battery out, it took a lot of gentle movements to release it from the strips of glue sticking it along its back face to the rest of the phone. Yes, first run something along the bottom edge back and forth to remove glue there, but the main glue is on the back face. I used a plastic tool to go a short distance up each side of the battery too, so it was easier to lift the corners of the battery slightly. Then you have to keep moving it bit by bit trying to raise it slightly, wedging something into the bottom gap. Once you can slide something just underneath the bottom edge, its a case of gradually pressing the wedge under the battery and moving it side to side to gradually release a bit more glue and so on.
My big problem came when putting the back of the phone on again. I squished the tiny clips on one side so that instead of being L-shaped they doubled up on themselves, so they wouldn't clip back into place. I'd suggest you do what I wish I'd done, and study the clips with a magnifying glass, so you can see how they go in. There are three clips at the top edge that slide in first, then gradually work your way back equally down each side. Some of the clips are just straight, and fit into tiny slots, while the L-shaped ones make a snapping sound as they clip in. On one of the bottom corners there is a clip with a hooked end, but that fitted in OK. I fixed the problems with the L-shaped clips getting bent double by shoving a needle in one end of the mess, and then in the other end, until the mess straightened out back into an L. If you have this problem, you might also need to straighten up the L with some small pliers.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 33,381
