Introdução
Huawei Ascend G7 is not difficult to take apart, but some parts are glued and need attention
O que você precisa
Under the top frame there are 3 screws. The frame is glued. Heat without exaggerating the frame and lever to disengage.
Under the Lower frame there are three screws. The frame is glued. Heat without exaggerating the frame and lever to disengage.
This is the same as removing as removing the upper frame casing
Disconnect the battery connector.
If The battery is stuck, remove it very carefully.
Remove the screw next to the video connector.
Your almost to the finish line! Just 3 more steps to go.
Gently rotate outside the motherboard, making sure not to break the little indicated connector
If your new display assembly comes with this ribbon cable already installed, disconnect the old one now.
Heat the front.
Using a plastic tool to separate the lock display / touch screen from the main body.
36 outras pessoas executaram este guia.
4 comentários
Hi , thanks this info is great . My G7 has a broken touch screen but works fine . I have seen replacement screens and units which include the digiboard ? So do I need to still remove the pcb or just the frame to get to the edge of the touch screen ? is it easy to replace the touch sreen alone ? look forward to your reply . Regards Carl.
Step 8 - the battery stock very much, I inserted a credit card in between the casing and the battery to detach it. I guess that bending the battery is very dangerous!
Step 15 - This part means the black flat cable with the three buttons ;-)
Step 16 - The new display needed a small film of glue
