Ir para o conteúdo principal
Hp Pavilion dv6-2155dx Optical Drive Replacement
O que você precisa
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: passo 1, imagem 1 %32 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: passo 1, imagem 2 %32
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 2, imagem 1 %32
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 3, imagem 1 %32 Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 3, imagem 2 %32
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 4, imagem 1 %32 Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 4, imagem 2 %32
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
Conclusão
Joseph Sanda
Membro desde: 03/10/16
522 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 799
