Introdução
In this guide you will learn how to remove the keyboard from the HP Pavilion dv6-2155dx.
O que você precisa
Loosen the screws using Phillips #01 screwdriver with the extension attached.
Remove the six screws. Four are marked with a keyboard icons, two are located on the top corner.
Remove the three screws located in the battery port.
6 outras pessoas executaram este guia.
