Ir para o conteúdo principal
Hp 15-f305dx Keyboard Replacement
O que você precisa
  1. Hp 15-f305dx Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Keyboard Replacement: passo 2, imagem 1 %32
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Keyboard Replacement: passo 3, imagem 1 %32 Hp 15-f305dx Keyboard Replacement: passo 3, imagem 2 %32 Hp 15-f305dx Keyboard Replacement: passo 3, imagem 3 %32
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Keyboard Replacement: passo 4, imagem 1 %32 Hp 15-f305dx Keyboard Replacement: passo 4, imagem 2 %32
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Keyboard Replacement, Keyboard: passo 5, imagem 1 %32
    • Flip the laptop around.
  6. Hp 15-f305dx Keyboard Replacement: passo 6, imagem 1 %32 Hp 15-f305dx Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
  7. Hp 15-f305dx Keyboard Replacement: passo 7, imagem 1 %32 Hp 15-f305dx Keyboard Replacement: passo 7, imagem 2 %32
    • Pry the keyboard out of the laptop gently and flip the keyboard around.
  8. Hp 15-f305dx Keyboard Replacement: passo 8, imagem 1 %32
    • Disconnect the connected cable from the mainboard.
Conclusão
Brandon
Membro desde: 03/23/18
681 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 631
