1. Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Turn the computer upside down on a flat surface.
    • Turn the computer upside down on a flat surface.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery. Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery. Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  5. Lift the battery from the middle and then pivot it outward to remove it from the comp. Lift the battery from the middle and then pivot it outward to remove it from the comp.
    • Lift the battery from the middle and then pivot it outward to remove it from the comp.
Conclusão
Brandon
613 reputação
4 Guides authored
Equipe
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Todo: 65
