Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If your mac is having trouble recognizing a replacement battery or other components, you may need to repair your main disk permissions. Follow this guide as a first step in troubleshooting.
You will want to first open Disk Utilities, which can be found in the Applications folder under Utilities
Or you can take the shortcut and use Spotlight!
Once opened, you should be presented with a window that looks like this.
You will want to select the name of your Mac OS X Startup disk in the left column.
After clicking on the name of your Hard drive, you will be presented with a few different options at the top.
The First Aid heading is what you will want to be under.
Click on the Verify Disk Permissions, starting the process.
Congrats! You successfully repaired your disk permissions!
52 outras pessoas executaram este guia.
2 comentários
verify disk does not come up after I enter fix and the procedure stops, I am running high sierra 10.13.6, Help please
Did anyone help you? I'm running through the same issues?
