Ir para o conteúdo principal
How to verify and repair Mac OS X Disk Permissions
  1. How to verify and repair Mac OS X Disk Permissions, How to verify and repair Mac OS X Disk Permissions: passo 1, imagem 1 %32 How to verify and repair Mac OS X Disk Permissions, How to verify and repair Mac OS X Disk Permissions: passo 1, imagem 2 %32
    • You will want to first open Disk Utilities, which can be found in the Applications folder under Utilities
    • Or you can take the shortcut and use Spotlight!
  2. How to verify and repair Mac OS X Disk Permissions: passo 2, imagem 1 %32 How to verify and repair Mac OS X Disk Permissions: passo 2, imagem 2 %32
    • Once opened, you should be presented with a window that looks like this.
    • You will want to select the name of your Mac OS X Startup disk in the left column.
    • After clicking on the name of your Hard drive, you will be presented with a few different options at the top.
    • The First Aid heading is what you will want to be under.
    • Click on the Verify Disk Permissions, starting the process.
  3. How to verify and repair Mac OS X Disk Permissions: passo 3, imagem 1 %32 How to verify and repair Mac OS X Disk Permissions: passo 3, imagem 2 %32
    • This usually will take anywhere from 3 minutes to 15 minutes. The best thing to do is to wait.
    • As time progresses, you will see information pop up in the window highlighted.
    • This is good, it means that it is seeing the problems that may be keeping your computer from running well.
  4. How to verify and repair Mac OS X Disk Permissions: passo 4, imagem 1 %32 How to verify and repair Mac OS X Disk Permissions: passo 4, imagem 2 %32
    • After verifying the disk permissions, go ahead and select repair disk permissions to start that process.
    • During that time, which again should take anywhere from 3-10 minutes, feel free to get up, walk around for a few minutes, or go pet a cat.
Conclusão
Congrats! You successfully repaired your disk permissions!
54 outras pessoas executaram este guia.
Mike
Membro desde: 11/01/10
14.455 Reputação
Autoria de 3 guias
2Comentários do guia
verify disk does not come up after I enter fix and the procedure stops, I am running high sierra 10.13.6, Help please
gene kaz - Responder
Did anyone help you? I'm running through the same issues?
Marco Saavedra -
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 42
Últimos 30 dias: 145
Ao todo: 16,435
