Ir para o conteúdo principal
How to use a floor jack with the 2010-2017 Suzuki Swift
O que você precisa
  1. How to use a floor jack with the 2010-2017 Suzuki Swift, jack up your car: passo 1, imagem 1 %32 How to use a floor jack with the 2010-2017 Suzuki Swift, jack up your car: passo 1, imagem 2 %32 How to use a floor jack with the 2010-2017 Suzuki Swift, jack up your car: passo 1, imagem 3 %32
    • CAUTION: THIS PROCESS IS POTENTIALLY DANGEROUS. Be aware of your surroundings and do not go underneath your vehicle until this step is completed.
    • Make sure the handbrake is on, and the gear is in reverse for manual or park for an automatic transmission car.
    • Follow the safety instructions of the jack stand and jack.
    • Refer to this guide for more detailed information on how to jack up a car.
    • Put the jack under the rear frame hook and jack up the back of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the rear jack supports. Slowly lower the weight of the car onto them by lowering the jack.
    • Put the jack under the front sub frame and jack up the front of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the front jack supports. Slowly lower the weight of the car onto them by lowering the jack.
Conclusão
To lower the car, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
knipwim
Membro desde: 09/01/18
11.213 Reputação
Autoria de 36 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 32
Últimos 30 dias: 97
Duração total: 4,140
