Introdução
The LSA Plus system is a widely used solution for connecting wires to terminal blocks in telecommunication networks. The Krone LSA Plus tool is a specialized tool designed to aid in the installation and maintenance of these systems.
O que você precisa
There is a difference between LSA and LSA Plus:
LSA: The insulation displacement terminals are perpendicular to the cable.
LSA Plus: With this technology, the insulation displacement connectors are at an angle of 45° to the cable.
To enable or disable the scissors, turn the wheel in the middle of the tool.
To disable the sensor, move the metal bracket at the front of the tool towards the toolhead.
Ferramenta utilizada neste passo:Flush Cutter$29.99
Use electronics sidecutters to trim the excess.
Press on the tab to release the wire removal hook.
Use the hook to pull out the wire you want to remove.
Good luck on your next project!
