Introdução
This guide will demonstrate how to update Kali Linux to the latest version. Updating and Upgrading should be the crucial first step in any workflow when using Kali Lunix. You don't want to start working with an outdated system or with outdated tools.
Press Ctrl + Alt + T to open the Terminal Interface.
To update and upgrade Kali enter the following command: sudo apt update -y && sudo apt upgrade -y
Once the updates and upgrades are complete some of the packages won't be required. You can remove those packages with the command: sudo apt autoremove -y
In the event that you don't have the latest release of Kali Linux, or didn't install it, you're going to want to use the following command
sudo apt update && sudo dist-upgrade -y
Be cautious, as this is the equivalent a major Windows Update and can mess up a system that you have been using for a while.
17 outras pessoas executaram este guia.
2 comentários
Hello / Hallo - many thanks / vielen Dank... Top :) .... Regards / Grüße
En la versión de kali 2024, al realizar el dist-upgrade, me dañó la instalación.
Ejecuté sudo apt upgrade -y y me actualizó sin problemas.
Removí los programas con la instrucción supo apt autoremove -y
