Ir para o conteúdo principal
How to turn on your dead, not charging Samsung tab 2
    I have read there is a capacitor that will hold a charge once the battery reaches a lower charge of, I believe 8%. This somehow hangs the device’s ability to charge the battery.
    It was suggested that you allow the device to discharge as far as possible, then, simultaneously hold the center of the volume button and the Home key , twice without releasing either buttons in order to get that capacitor to completely discharge. This powers down the device and it is supposed to shut down, restart and shut down again
    It has been a while since I discovered that suggestion and I believe it worked for me at the time from YouTube!
    Good luck & Happy Computing!
    Diana - Responder
    I just want to confirm that this suggestion works! My tablet’s cable was broken, so the tablet was not charged for a very long time. When I finally bought a new cable and tried to charge it, I’d just briefly see the battery icon and then it would automatically turn off, only to turn on again for a few seconds, then the cycle would repeat. I dissassembled it (easier than you may think) and disconnected the backlight cable and the touchscreen/screen cable, leaving only the ribbon that comes from the charge cable. I measured with a multimeter from time to time and I was able to see the battery slowly charging until it reached 3.7v. Then I unplugged it, reconnected the two ribbon cables and restarted it using only the battery. Android finally booted for the first time in more than a year! I quickly plugged it back again and since then it has been charging with no issues.
    Leandro Tami - Responder
Conclusão
10 outras pessoas executaram este guia.
MrSarbine
Membro desde: 12/24/15
347 Reputação
Autoria de 1 guia
2 comentários
I had the same problem with this tablet.
Original charger didn't work, battery symbol appeared and disappeared again and again.
I fixed it in a quite simple way without opening the device.
I remembered that I got a bad charger, very bad, so bad that a conected smartphone won't even work properly, as there is so much high frequency noise on the 5V-output. By means of this noise this very-very-bad charger put the needed extra-portion of energy into the battery, that the device was able to get behind this critical point at startup, that made it switch off before, and charging could be finished with a proper charger.
Problem: solved!
Reinhard Kaune - Responder
Are you saying replacing the charger fixed the issue for you? Or are you saying temporarily using a better charger to get the battery above 5% and then using any charger after that to finish the job fixed the issue?
gatchi -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 75
Duração total: 3,499
