Ir para o conteúdo principal
How to Tighten GEN 2 Wheelchair Wheels
O que você precisa
  1. How to Tighten GEN 2 Wheelchair Wheels, How to Tighten GEN 2 Wheelchair Wheels: passo 1, imagem 1 %32
    • Inspect the chair to see which wheel is loose.
    • Tighten the outer bolt with a 19 mm socket wrench.
  2. How to Tighten GEN 2 Wheelchair Wheels: passo 2, imagem 1 %32
    • Tighten the nut facing the inside of the chair with a 19 mm wrench.
Conclusão
If wheel does not feel properly secured, keep tightening the wheel in small amounts until the wheel is secure.
Kali Slaughter
Membro desde: 04/19/13
207 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 14-8, Maness Spring 2013 Membro de Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,881
