Pular para o conteúdo principal
Introdução
This guide shows how to tighten the main wheels on the wheelchair.
Ferramentas
Peças
Nenhum componente especificado.
  1. Inspect chair to see which wheel is loose. Tighten the outer bolt with a 19 mm socket wrench.
    • Inspect chair to see which wheel is loose.
    • Tighten the outer bolt with a 19 mm socket wrench.
    • Tighten the nut on the inside with a 19 mm wrench.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
Conclusão
If wheel does not feel properly secured, keep tightening the wheel in small amounts until the wheel is secure.
Kali Slaughter
Membro desde: 19-04-2013
207 reputação
5 Guias de autoria
Equipe
Cal Poly, Team 14-8, Maness Spring 2013 Membro de Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Membros
7 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Todo: 1,006
