Ir para o conteúdo principal
How to restore a shrunken sweater
O que você precisa
  1. How to restore a shrunken sweater, How to restore a shrunken sweater: passo 1, imagem 1 %32
    • Add 2/3 full of water into the washbasin.
    • Add 20 ml of Baby Shampoo into the washbasin.
    • The volume of water needed depends on the size of the sweater. The larger the sweater, the more water needed.
  2. How to restore a shrunken sweater: passo 2, imagem 1 %32
    • Soak the sweater into the washbasin with soapy water for 15 mins.
  3. How to restore a shrunken sweater: passo 3, imagem 1 %32 How to restore a shrunken sweater: passo 3, imagem 2 %32 How to restore a shrunken sweater: passo 3, imagem 3 %32
    • Take out the sweater from the washbasin with soapy water.
    • Remove the sweater to the bucket filled with fresh warm water.
    • Rinse the sweater thoroughly.
  4. How to restore a shrunken sweater: passo 4, imagem 1 %32
    • Take out the sweater from the bucket.
    • Wring the clothes gently to get excessive water out.
  5. How to restore a shrunken sweater: passo 5, imagem 1 %32
    • Place the sweater flat in the center of the bath towel.
  6. How to restore a shrunken sweater: passo 6, imagem 1 %32 How to restore a shrunken sweater: passo 6, imagem 2 %32 How to restore a shrunken sweater: passo 6, imagem 3 %32
    • Roll while wringing the towel together with the sweater in order to dry the sweater.
    • Redo the process for a couple times until the sweater is dry to the touch.
    • Unfold the towel and take out the sweater
    • Spread out the sweater flat and let it dry.
Conclusão
Uma outra pessoa concluiu este guia.
Zhou Zhou
Membro desde: 10/26/18
148 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S2-G8, Bender Fall 2018 Membro de UC Davis, Team S2-G8, Bender Fall 2018
UCD-BENDER-F18S2G8
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 432
