Ir para o conteúdo principal
How to reset the SMC, PRAM and NVRAM on an iMac Pro
  1. How to reset the SMC, PRAM and NVRAM on an iMac Pro, SMC reset Part 1: passo 1, imagem 1 %32
    • Choose Apple menu > Shut Down.
    • After your Mac shuts down, press and hold its power button for 10 seconds.
    • Release the power button, then wait a few seconds.
    • Press the power button again to turn on your Mac.
    • If that did not solve the issue, move on to Step 2
    After the iMac Pro shut down, I pressed and held the power button for 10 seconds. It began to power up so this didn’t seem to work.
    C Adams - Responder
    What is the problem you are trying to solve by attempting to do these resets?
    [deleted] -
  2. How to reset the SMC, PRAM and NVRAM on an iMac Pro, SMC Reset Part 2: passo 2, imagem 1 %32
    • After your Mac shuts down, unplug the power cord.
    • Wait 15 seconds.
    • Plug the power cord back in.
    • Wait 5 seconds, then press the power button again to turn on your Mac.
  3. How to reset the SMC, PRAM and NVRAM on an iMac Pro, PRAM and NVRAM reset: passo 3, imagem 1 %32
    • Shut down your Mac.
    • Then turn it on and immediately press and hold these four keys together: Option, Command, P, and R.
    • You can release the keys after about 20 seconds, during which your Mac might appear to restart.
    • You can release the keys after the Apple logo appears and disappears for the second time.
    • You must have a wired keyboard made by Apple in order for this to work.
    • You can buy one from Amazon here.
    I have never been able to do a PRAM reset on my iMac Pro. I even got the stock extended wireless keyboard out of the box to try to do it, and never get the satisfying triple gong of yore.
    C Adams - Responder
    It needs to be a wired keyboard made by Apple, not a wireless keyboard.
    [deleted] -
    Hello C Adams, it is very true I share Aaron's grip, you have to use an Original Apple keyboard with cable to be able to restart the SMC + PRAM + and + NVRAM, and any on the iMac or any Mac, greetings
    Miguel -
    it worked! and, if you want your startup sound back on the iMac Pro, use this terminal command:
    sudo nvram StartupMute=%00
    Admin User - Responder
    You don’t have to shut down the computer; restarting works just as well. Just ensure the four keys are down as soon as possible after the screen goes dark.
    A wireless keyboard connected with a Lightning-to-USB cable permits parameter RAM reset. You don’t have to buy a new wired keyboard.
    trudyscousin - Responder
    Command-Option-P-R works with a wireless keyboard wired with the lightning cable (the one coming with the iMac Pro); however do not shutdown the Mac first.
    Boot the Mac, restart it. As the screen goes black and before the Apple logo shows, press Command-Option-P-R and hold it ; the screen will stay blank and then after about 20s the apple logo will appear and the dong will be heard. Keep pressing Command-Option-P-R until the logo disappear and re-appear a 2nd time with the dong sound
    jyavenard - Responder
Conclusão
If you have tried all of these resets and still have problems, head on over to our Answers Forum!
8 outras pessoas executaram este guia.
[deleted]
Membro desde: 08/28/18
26.409 Reputação
Autoria de 21 guias
Um comentário
one of my thunderbolt ports stopped working. I used the SMC and PRAM reset and they all worked afterwards. thanks!
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 95
Últimos 30 dias: 423
Duração total: 38,914
