Ir para o conteúdo principal
How to reset the PIN of a Flipper Zero
  1. How to reset the PIN of a Flipper Zero, Reset your PIN: passo 1, imagem 1 %32
    • Hold the Up- and Back-buttons for 30 seconds.
  2. How to reset the PIN of a Flipper Zero, Confirm the Reset: passo 2, imagem 1 %32
    • Confirm the reset procedure by holding the Right-button.
Conclusão
Try to remember your PIN next time!
4 outras pessoas executaram este guia.
Sebastian
Membro desde: 08/19/18
31.061 Reputação
Autoria de 71 guias
4Comentários do guia
Every time I attempt this, it goes black 20 seconds in the 30 seconds and resets the locked timer.
vmmmp - Responder
You have to wait until the timer ends and it asks for the passcode again. Only THEN can you perform the steps. I just successfully did so after experiencing the same issue as you.
Massimo Cracchiolo - Responder
If i do the same steps my flipper says: Flipper crashed and was rebooted HardFault. What can i do? is there maybe another way ?
Anke Seeland (Ankmaus) - Responder
i got the pin for the flipper : Left Up Right Down = press Insert
Cezar Khaloul - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 31
Últimos 30 dias: 188
Ao todo: 14,004
