Ir para o conteúdo principal
How to replace the Nintendo 2DS charging port
O que você precisa
Vídeo de Apresentação
  1. How to replace the Nintendo 2DS charging port, Battery: passo 1, imagem 1 %32
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. How to replace the Nintendo 2DS charging port: passo 2, imagem 1 %32 How to replace the Nintendo 2DS charging port: passo 2, imagem 2 %32
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. How to replace the Nintendo 2DS charging port: passo 3, imagem 1 %32 How to replace the Nintendo 2DS charging port: passo 3, imagem 2 %32 How to replace the Nintendo 2DS charging port: passo 3, imagem 3 %32
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
  4. How to replace the Nintendo 2DS charging port, Rear Panel: passo 4, imagem 1 %32
    • Remove the ten Phillips screws attaching the rear panel.
  5. How to replace the Nintendo 2DS charging port: passo 5, imagem 1 %32
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
  6. How to replace the Nintendo 2DS charging port: passo 6, imagem 1 %32
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
  7. How to replace the Nintendo 2DS charging port, Remove Side Panels: passo 7, imagem 1 %32 How to replace the Nintendo 2DS charging port, Remove Side Panels: passo 7, imagem 2 %32
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
    • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
  8. How to replace the Nintendo 2DS charging port, Unscrew Motherboard: passo 8, imagem 1 %32
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
    • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
  9. How to replace the Nintendo 2DS charging port, Remove Top Panel: passo 9, imagem 1 %32 How to replace the Nintendo 2DS charging port, Remove Top Panel: passo 9, imagem 2 %32 How to replace the Nintendo 2DS charging port, Remove Top Panel: passo 9, imagem 3 %32
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
  10. How to replace the Nintendo 2DS charging port, Remove Motherboard: passo 10, imagem 1 %32 How to replace the Nintendo 2DS charging port, Remove Motherboard: passo 10, imagem 2 %32
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
  11. How to replace the Nintendo 2DS charging port, Charging Port: passo 11, imagem 1 %32 How to replace the Nintendo 2DS charging port, Charging Port: passo 11, imagem 2 %32
    • Desolder and remove the charging port
    • Don't try to force the port off the board. If it's not coming off, the solder isn't fully melted
  12. How to replace the Nintendo 2DS charging port: passo 12, imagem 1 %32
    • Set the new port in the board, then solder it in place
Conclusão
To reassemble your device, follow these instructions in reverse order, starting at step 10
5 outras pessoas executaram este guia.
Nick Myers
Membro desde: 04/15/18
5.114 Reputação
Autoria de 30 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 66
Últimos 30 dias: 276
Ao todo: 10,493
