Ir para o conteúdo principal
How to replace motor of AEG Lavatherm tumble dryer
  1. How to replace motor of AEG Lavatherm tumble dryer, Bring the tumble dryer into service mode: passo 1, imagem 1 %32 How to replace motor of AEG Lavatherm tumble dryer, Bring the tumble dryer into service mode: passo 1, imagem 2 %32 How to replace motor of AEG Lavatherm tumble dryer, Bring the tumble dryer into service mode: passo 1, imagem 3 %32
    • Before you begin, disconnect the dryer from the power socket. Be careful not to touch any large capacitors—they can electrocute you. You can manually discharge them by making a discharge tool.
    • Bring the tumble dryer into service mode by following the instructions in this video: https://youtu.be/MPirZGgntmE
  2. How to replace motor of AEG Lavatherm tumble dryer, Narrow down the problem: passo 2, imagem 1 %32
    • By spinning the drum using service mode #3, and by simply turning the drum by hand, you can hear that something is not right. I suspect that it has to be a faulty bearing, or worse: the motor itself. https://youtu.be/v1mC68JpMK4
  3. How to replace motor of AEG Lavatherm tumble dryer, Lifting of the belt: passo 3, imagem 1 %32 How to replace motor of AEG Lavatherm tumble dryer, Lifting of the belt: passo 3, imagem 2 %32 How to replace motor of AEG Lavatherm tumble dryer, Lifting of the belt: passo 3, imagem 3 %32
    • To further narrow down the problem, you should lift the belt of the drive shaft. https://youtu.be/5y6D12VbnWw
    • With the belt lifted of the drive shaft and running test mode, it is clear that the motor is the source of the noise. https://youtu.be/7E6duSL5qig
    • The motor is labelled: Nidec db085d50e00 cl.180 P/N: 807252401
  4. How to replace motor of AEG Lavatherm tumble dryer, Remove the motor: passo 4, imagem 1 %32 How to replace motor of AEG Lavatherm tumble dryer, Remove the motor: passo 4, imagem 2 %32 How to replace motor of AEG Lavatherm tumble dryer, Remove the motor: passo 4, imagem 3 %32
  5. How to replace motor of AEG Lavatherm tumble dryer, Mounting the new motor and testing.: passo 5, imagem 1 %32 How to replace motor of AEG Lavatherm tumble dryer, Mounting the new motor and testing.: passo 5, imagem 2 %32
Conclusão
5 outras pessoas executaram este guia.
LarsWH
Membro desde: 03/05/16
887 Reputação
Autoria de 4 guias
4 comentários
Where did you buy your replacement motor?
Yotam p - Responder
I bought it from the local (Denmark) official distributor https://shop.aeg.dk/
LarsWH - Responder
Thank you! Just replaced the motor on my AEG heat pump tumble dryer. Great instructions.
lucy Knight - Responder
Thanks. Helped replace the belt
Michael Lajlev - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 34
Últimos 30 dias: 159
Duração total: 11,234
