Ir para o conteúdo principal
How to replace a bikini buckle
O que você precisa
  1. How to replace a bikini buckle, Locate the defect: passo 1, imagem 1 %32 How to replace a bikini buckle, Locate the defect: passo 1, imagem 2 %32 How to replace a bikini buckle, Locate the defect: passo 1, imagem 3 %32
    • In most cases, the buckle will not have broken, but just the stitching keeping the seam together
    • We will re-use the buckle
  2. How to replace a bikini buckle, Tidy the broken seam: passo 2, imagem 1 %32 How to replace a bikini buckle, Tidy the broken seam: passo 2, imagem 2 %32 How to replace a bikini buckle, Tidy the broken seam: passo 2, imagem 3 %32
    • Carefully remove the old broken threads from the defective seam, to obtain a clean area again.
  3. How to replace a bikini buckle, Position the buckle and pin it: passo 3, imagem 1 %32 How to replace a bikini buckle, Position the buckle and pin it: passo 3, imagem 2 %32 How to replace a bikini buckle, Position the buckle and pin it: passo 3, imagem 3 %32
    • Thread the strap back through the buckle and hold in place with your hand.
    • Check that the alignment is correct buy clipping it onto the other buckle
    • Note: this buckle is a sliding design which will only work on one alignment. Other buckles work in different ways, so be sure to check before sewing.
    • Pin the strap in place around the buckle, to secure it before sewing
  4. How to replace a bikini buckle, Sew the broken seam: passo 4, imagem 1 %32 How to replace a bikini buckle, Sew the broken seam: passo 4, imagem 2 %32 How to replace a bikini buckle, Sew the broken seam: passo 4, imagem 3 %32
    • Use a sewing machine to re-sew the broken seam
    • Offer-up the seam to the sewing machine, depress the foot, and remove any pins which are in the way of the needle
    • Make a locking stitch, followed by a straight stitch. Repeat the straights stitch 1-2 times and finish with another locking stitch.
  5. How to replace a bikini buckle, Reinforce the seam if needed: passo 5, imagem 1 %32 How to replace a bikini buckle, Reinforce the seam if needed: passo 5, imagem 2 %32 How to replace a bikini buckle, Reinforce the seam if needed: passo 5, imagem 3 %32
    • Add a second row of stitching to reinforce the fixation, if needed
  6. How to replace a bikini buckle, Finished and ready!: passo 6, imagem 1 %32 How to replace a bikini buckle, Finished and ready!: passo 6, imagem 2 %32 How to replace a bikini buckle, Finished and ready!: passo 6, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • You can fasten the buckle and stretch the straps to check if the repair is secure
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 166
