Ir para o conteúdo principal
How to repair loose threads
O que você precisa
  1. How to repair loose threads, Prepare the repair: passo 1, imagem 1 %32 How to repair loose threads, Prepare the repair: passo 1, imagem 2 %32 How to repair loose threads, Prepare the repair: passo 1, imagem 3 %32
    • Identify the snag
    • Prepare your needle - for this guide we are using a specialized "snag repair needle" which has a textured end. These are available from most sewing shops.
  2. How to repair loose threads, Pull snag loop through: passo 2, imagem 1 %32 How to repair loose threads, Pull snag loop through: passo 2, imagem 2 %32 How to repair loose threads, Pull snag loop through: passo 2, imagem 3 %32
    • Pass the needle through the bottom of the snag loop.
    • Wrap the thread around the sharp end of the needle.
    • Then, pass the needle through the fabric. The snag loop will also be pulled through by the textured part of the needle. Keep pulling it through, until both the needle and the snag loop are on the inside of the item.
  3. How to repair loose threads, Finished and ready!: passo 3, imagem 1 %32 How to repair loose threads, Finished and ready!: passo 3, imagem 2 %32 How to repair loose threads, Finished and ready!: passo 3, imagem 3 %32
    • Pull tightly on the thread to secure it to the back of the fabric.
    • Then, reposition the fabric appearance on the front, by stretching it to balance the tension.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Uma outra pessoa concluiu este guia.
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 8
Últimos 30 dias: 25
Duração total: 441
