Ir para o conteúdo principal
How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System
O que você precisa
  1. How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System, How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 1, imagem 1 %32 How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System, How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 1, imagem 2 %32 How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System, How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 1, imagem 3 %32
    • Disconnect all of the wand attachments from the unit.
  2. How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 2, imagem 1 %32 How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 2, imagem 2 %32
    • Remove all of the clear plastic holders. There are a total of seven screws to remove, and three plastic holders.
  3. How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 3, imagem 1 %32 How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 3, imagem 2 %32 How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 3, imagem 3 %32
    • Flip the unit on it's face, with a soft towel under it. Remove ten screws, all on the outer edge of the bottom of the unit. To keep screws together, and with the correct piece of the unit, try to use scotch or masking tape them on a strip of tape and tape them directly to the portion that you removed
  4. How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 4, imagem 1 %32
    • Gently pull the bottom, with its back facing up, outward and down to the floor, as to not disturb the connected wires, which are not long enough to pull straight downward.
  5. How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 5, imagem 1 %32 How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 5, imagem 2 %32 How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 5, imagem 3 %32
    • Look over all of the hoses, their connections and the filters inside each end to make sure there are no holes, cracks or kinks in them. Make certain that the hoses are tightly connected to each port and there is not a leak. Inspect the filters for clogs, too much dust or tears.
    • Replace any bad hoses or connections. If the end of each hose is bad, simply cut the tip of it off and put it back on it's port. Throw away dirty or clogged filters, and replace them with new ones. To be safe, use either electrical or duct tape around the filter housing of each, to prevent air leaks or separation of the housing.
  6. How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 6, imagem 1 %32 How to repair hoses for 4 Function Diamond Microdermabrasion Unit SLY-08XLT. NV-07D Vacuum System: passo 6, imagem 2 %32
    • Check the interior for any debris or dust blocking the fan and fan motor and simply remove it or clean it out. Check for loose wires, bad connections or wires that are damaged.
Conclusão
4 outras pessoas executaram este guia.
Pam
Membro desde: 02/25/13
183 Reputação
Autoria de 1 guia
6 comentários
Hello, can you please tell me where can I buy parts for this machine? I have it allready 7 years and I´m very happy with it, but my skin scrubber (handpeace) doesn´t work any more. thank you, Kristina
Kristina Jurisic - Responder
Kristina.....i have been sick... Sorry for the delay in answering. I'll have to look up the information, but most of the parts are generic pieces. Depending on what you need to order... It could be as easy ead going to a hardware store. Let me know what parts you're looking for and I'll see if I can find them.
Pam -
If anyone knows where it's can be rapair it in NY area
elinaaronin - Responder
My microdermabrasion has not .. Function the air of the machine is thru away ..
Andy Gregorio - Responder
I am getting ready to set up my machine, do you have a better manual that show you in picture form of each item and how it works. There is one piece I have no idea how to use it , it looks like a small wand. It would be nice to show how the to insert rings and filters in a picture form.
Thank you
Sissy. 04-16-2020
ccountrycottage - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 2,690
