Introdução
Cheap fog machines are often damaged because of poor quality. Most of these damages can be easily repaired. This guide can be used to repair the more common problems that can be encountered when dealing with this type of fog machine.
The fog machine I repaired is called 'eurolite n-19', but it is also sold under other names.
Peças
Não são necessárias peças.
  1. Open the fog machine by removing the screws at the sides of the fog machine with the screwdriver
    • Open the fog machine by removing the screws at the sides of the fog machine with the screwdriver
    • Remove the outer casing of the fog machine.
  2. If the fog machine does not heat up the fuse or another heating element could be malfunctioning
    • If the fog machine does not heat up the fuse or another heating element could be malfunctioning
    • If there is nothing coming out of the fog machine the pump of the fog machine could be malfunctioning
    • Detailed info on finding out what's wrong can be found at: tec-shack's fog machine repair guide
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Acquire the necessary tools for repair
    • Acquire the necessary tools for repair
    • In this instance, all that was needed was a new heat fuse and new spade connectors
    • Remove the heat fuse
    • Remove the spade connectors
    • Connect the new heat fuse and spade connectors to their respective locations
    • The heat fuse sits under the bimetal. (Cannot be seen clearly in the picture)
  5. Simply reverse these instructions to reassemble the fog machine.
    • Simply reverse these instructions to reassemble the fog machine.
Conclusão
4 outras pessoas concluíram este guia.
rjay
206 reputação
Autoria de 1 guia
My fogger heater is jam how can I clean it?
vishal_kishor777 - Responder
hmm… I think I could have written a better guide myself. Okay so I have a 3 pin XLR for phase does anyone know how this works also I noted that the fuse was melted into its holster and the pump seems dead. My Fogger also has some kind of potentiometer which controls the heating element which is like a ceramic sandwich and two spark plugs… I also was wondering if glycerin fog juice can be made with vegetable glycerin or the glycol type or if this is what cloggs the machine. Also will clr work or be dangerous fume wise? Can you market glycerine as fog juice thickener like STP fuel additives for cars?? g0pg.xyz is my website you can learn how to force push graphite if you look for the post with yoda!
Ember Leona - Responder
Where can I buy a fuse like this? Have looked over the net, but could not find any shops that would sell CH-15 fuse, used in this fog machine. If anyone knows about this, please share info. Thanks! By the way, I’m based in EU.
Giedrius Stasiulis - Responder
My fog machine is not pumping out smoke
Ohwaga Kerry - Responder
No power to my fog machine ?
David McCartie - Responder
Visualizar Estatísticas:
Últimas 24 horas: 21
Últimos 7 dias: 102
Últimos 30 dias: 493
Todo: 39,560
