Ir para o conteúdo principal
How to repair an iPhone that won't charge - Tristar Replacement
O que você precisa
  1. How to repair an iPhone that won't charge - Tristar Replacement, Check for a new charger: passo 1, imagem 1 %32
    • Your cable could be bad, try a new one, possibly MFI certified ! (Made For iPhone) Or try a known-good one.
    • Try a new charging brick, or a known-good one that delivers at least 5V-1A
    Pergunte ao FixBot
    Comentar
  2. How to repair an iPhone that won't charge - Tristar Replacement, Checking the charging port: passo 2, imagem 1 %32
    • Check your charging port, it could be really dirty or obstructed
    • If it looks dirty, you can take the risk to insert a thin tool and try to pry out the dirt. I am not responsible for the harm you could do to your phone !
    Pergunte ao FixBot
    Comentar
  3. How to repair an iPhone that won't charge - Tristar Replacement, Try known-good internals: passo 3, imagem 1 %32
    • Try a known-good battery. Replace it if your phone charges again.
    • Try a known-good Lightning charging port. Replace it if your phone charges again.
    • I know, this is a picture of an iPhone 7, check the video for the 6S on the next step.
    Pergunte ao FixBot
    Comentar
    • The whole french version of the process, video does help if you are an english-speaker !
    Pergunte ao FixBot
    Comentar
  4. How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: passo 5, imagem 1 %32 How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: passo 5, imagem 2 %32
    • If you are still reading, bad news, you probably have a motheboard problem !
    • It's probably U4500, or Tristar that's causing it, it fails very frequently on iPhones. You'll have to replace it.
    Pergunte ao FixBot
    Comentar
    • Video tutorial for Tristar replacement on iPhone 6S
    Pergunte ao FixBot
    Comentar
Conclusão
15 outras pessoas executaram este guia.
Alexandre Isaac
Membro desde: 04/07/13
3.582 Reputação
Autoria de 8 guias
Equipe
The Repair Academy Membro de The Repair Academy
Business
1 Membro
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 22
Últimos 30 dias: 163
Ao todo: 15,258
