Ir para o conteúdo principal
How to repair a trouser/cuff hem (without shortening)
O que você precisa
  1. How to repair a trouser/cuff hem (without shortening), Identify the defect: passo 1, imagem 1 %32 How to repair a trouser/cuff hem (without shortening), Identify the defect: passo 1, imagem 2 %32 How to repair a trouser/cuff hem (without shortening), Identify the defect: passo 1, imagem 3 %32
    • Identify the defective area and assess how large the damage is.
  2. How to repair a trouser/cuff hem (without shortening), Prepare the stitching: passo 2, imagem 1 %32 How to repair a trouser/cuff hem (without shortening), Prepare the stitching: passo 2, imagem 2 %32 How to repair a trouser/cuff hem (without shortening), Prepare the stitching: passo 2, imagem 3 %32
    • Cut away any damaged thread around the hole, to create a clean surface to repair.
    • Take care: don't cut away fabric, as this will shorten the repair.
    • Turn the edges of the hole inside, so that they are tucked inside the hole.
  3. How to repair a trouser/cuff hem (without shortening), Sew the repair: passo 3, imagem 1 %32 How to repair a trouser/cuff hem (without shortening), Sew the repair: passo 3, imagem 2 %32 How to repair a trouser/cuff hem (without shortening), Sew the repair: passo 3, imagem 3 %32
    • Pin the folded parts of the hole securely in place.
    • Prepare the sewing machine and offer up the repaired area.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Depress the sewing machine foot and remove any pins in the way of the sewing route. Start sewing a straight line from one side of the hole to the other, close to the edge of the hem, and add a lock stitch at the beginning and end.
  4. How to repair a trouser/cuff hem (without shortening), Finished and ready!: passo 4, imagem 1 %32 How to repair a trouser/cuff hem (without shortening), Finished and ready!: passo 4, imagem 2 %32 How to repair a trouser/cuff hem (without shortening), Finished and ready!: passo 4, imagem 3 %32
    • Finish the sewing and cut the loose thread to make a neat finish.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Uma outra pessoa concluiu este guia.
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 47
Duração total: 497
