Ir para o conteúdo principal
How to repair a hook & loop fastening
O que você precisa
  1. How to repair a hook & loop fastening, Identify the defect: passo 1, imagem 1 %32 How to repair a hook & loop fastening, Identify the defect: passo 1, imagem 2 %32 How to repair a hook & loop fastening, Identify the defect: passo 1, imagem 3 %32
    • Check the defective area, and assess how big the repair will need to be.
    • Is the hook & loop part still mostly held in place with the original stitching? If so (like our example) then only a small repair is needed.
  2. How to repair a hook & loop fastening, Prepare & repair: passo 2, imagem 1 %32 How to repair a hook & loop fastening, Prepare & repair: passo 2, imagem 2 %32 How to repair a hook & loop fastening, Prepare & repair: passo 2, imagem 3 %32
    • Cut away any damaged thread around the defect, to provide a clean base for the repair.
    • Then, position the item under the sewing machine, and make a small locking stitch with the forward & reverse function.
    • Tip: use the iFixit basic sewing resources for more help on sewing machine setup.
    • Continue sewing around the defective zone, following the line of the original thread.
  3. How to repair a hook & loop fastening, Finished and ready!: passo 3, imagem 1 %32 How to repair a hook & loop fastening, Finished and ready!: passo 3, imagem 2 %32 How to repair a hook & loop fastening, Finished and ready!: passo 3, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • Note: we have used a contrast thread and a basic sewing pattern to demonstrate this repair. Bu you can have fun with bright colours, or interesting stitch patterns to further embellish your repair.
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 31
Duração total: 327
