Ir para o conteúdo principal
How to repair a hole in woven textile (using a sewing machine)
O que você precisa
  1. How to repair a hole in woven textile (using a sewing machine), Identify the hole: passo 1, imagem 1 %32 How to repair a hole in woven textile (using a sewing machine), Identify the hole: passo 1, imagem 2 %32 How to repair a hole in woven textile (using a sewing machine), Identify the hole: passo 1, imagem 3 %32
    • Identify the tear or hole in your garment and note the size: is it a large tear or a small tear?
    • Tip: smaller holes might be fixable using a self-adhesive patch. Check out our guide on this technique before pulling out the sewing machine!
  2. How to repair a hole in woven textile (using a sewing machine), Prepare the repair: passo 2, imagem 1 %32 How to repair a hole in woven textile (using a sewing machine), Prepare the repair: passo 2, imagem 2 %32 How to repair a hole in woven textile (using a sewing machine), Prepare the repair: passo 2, imagem 3 %32
    • Turn the item inside-out, and lay it on a flat and clean surface with the tear fully exposed. Inspect the tear, and use scissors to gently cut any frayed edges.
    • Extra: If the fabric is wrinkled or creased, use a hot iron to smooth the area around the repair first.
    • Pinch the seam together carefully, to create an accurate match. Ensure there is enough fabric pinched together to fit underneath the sewing machine foot, and be sewn together.
    • Use sewing pins to tack the two sides together. The goal is to hold the fabric in place, in exactly the same orientation as you had it pinched by hand. This is an important step, as it will determine the location and accuracy of the final repair.
  3. How to repair a hole in woven textile (using a sewing machine), Use the sewing machine to fix the hole: passo 3, imagem 1 %32 How to repair a hole in woven textile (using a sewing machine), Use the sewing machine to fix the hole: passo 3, imagem 2 %32 How to repair a hole in woven textile (using a sewing machine), Use the sewing machine to fix the hole: passo 3, imagem 3 %32
    • Time to sew the repair closed! Take time to set up the sewing machine, and create a clean and open area to work in.
    • Tip: Use the iFixit resources for setting up a sewing machine, and practicing basic stitch techniques on some scrap fabric first.
    • Carefully offer up the item to the sewing machine, and position one end of the repair under the needle, and depress the foot to hold the item in place. Set the machine to a straight stitch.
    • Take care: remove the tacking pins one-by-one as needed - they must not run under the sewing machine, or it may break the sewing machine needle.
    • Make a locking stitch by using the reverse lever, and then make a single stitch along the length of the seam. At the end, secure the stitch with another lock stitch.
    • Note: Depending on the fabric, repeat the stich 1.2 times if needed, for extra durability.
  4. How to repair a hole in woven textile (using a sewing machine), Inspect & trim the repair: passo 4, imagem 1 %32 How to repair a hole in woven textile (using a sewing machine), Inspect & trim the repair: passo 4, imagem 2 %32 How to repair a hole in woven textile (using a sewing machine), Inspect & trim the repair: passo 4, imagem 3 %32
    • Remove the items from the sewing machine and inspect the repair. The old edges will be uneven, but the new stitch should look secure and well fastened on both ends.
    • Tip: Turn the item right-way-round and inspect it from the outside too. Does it look correct? This will be the final appearance of the repair, so any small adjustment should be made at this stage, by making additional stitches or unpicking and re-stitching any errors.
    • Carefully cut away the excess fabric which is no longer needed. Make the cut carefully, and not too close to the stitching, or the repair will break during use. Remove any sharp corners of fabric to prevent any itchiness during use.
  5. How to repair a hole in woven textile (using a sewing machine), Finished and ready!: passo 5, imagem 1 %32 How to repair a hole in woven textile (using a sewing machine), Finished and ready!: passo 5, imagem 2 %32 How to repair a hole in woven textile (using a sewing machine), Finished and ready!: passo 5, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • Turn the item right-way-round, and give a final check.
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 72
Duração total: 470
