Ir para o conteúdo principal
How to repair a hole in a crochet dishcloth
O que você precisa
  1. How to repair a hole in a crochet dishcloth, How to repair a hole in a crochet dishcloth: passo 1, imagem 1 %32
    • Collect the tools and materials you'll need.
  2. How to repair a hole in a crochet dishcloth: passo 2, imagem 1 %32 How to repair a hole in a crochet dishcloth: passo 2, imagem 2 %32 How to repair a hole in a crochet dishcloth: passo 2, imagem 3 %32
    • Identify any loose loops that may come undone if any yarn is pulled.
    • Put a safety pin through the loops, this will prevent the hole from getting any bigger.
  3. How to repair a hole in a crochet dishcloth: passo 3, imagem 1 %32 How to repair a hole in a crochet dishcloth: passo 3, imagem 2 %32 How to repair a hole in a crochet dishcloth: passo 3, imagem 3 %32
    • Pick one of the loose strands and tie the yarn to this strand.
    • Make three knots to ensure the knot will not come undone.
  4. How to repair a hole in a crochet dishcloth: passo 4, imagem 1 %32 How to repair a hole in a crochet dishcloth: passo 4, imagem 2 %32 How to repair a hole in a crochet dishcloth: passo 4, imagem 3 %32
    • Begin your first stitch by pushing the crochet hook through the stitch closest to the tied on yarn.
    • Next, wrap the yarn in front of the hook and pull it through the stitch making sure the hook catches the yarn.
  5. How to repair a hole in a crochet dishcloth: passo 5, imagem 1 %32 How to repair a hole in a crochet dishcloth: passo 5, imagem 2 %32 How to repair a hole in a crochet dishcloth: passo 5, imagem 3 %32
    • Continuing on your first stitch, wrap the yarn in front of the hook and pull it in the direction of the arrow through the loop wrapped around the crochet hook.
    • Move on to the next stitch where the orange arrow is pointing. Continue making stitches around the hole until there is a small opening.
  6. How to repair a hole in a crochet dishcloth: passo 6, imagem 1 %32 How to repair a hole in a crochet dishcloth: passo 6, imagem 2 %32 How to repair a hole in a crochet dishcloth: passo 6, imagem 3 %32
    • Once you have a small opening you will now close the hole. Using the same stitch used throughout the guide, make a stitch interlocking every other stitch.
    • The crochet hook should be moving in the direction the arrow is pointing.
  7. How to repair a hole in a crochet dishcloth: passo 7, imagem 1 %32 How to repair a hole in a crochet dishcloth: passo 7, imagem 2 %32 How to repair a hole in a crochet dishcloth: passo 7, imagem 3 %32
    • Continuing until the hole is completely closed.
    • Cut the yarn leaving about a 4 inch tail.
    • Pull the loop in the direction the arrow is pointing.
  8. How to repair a hole in a crochet dishcloth: passo 8, imagem 1 %32 How to repair a hole in a crochet dishcloth: passo 8, imagem 2 %32 How to repair a hole in a crochet dishcloth: passo 8, imagem 3 %32
    • Using the large threading needle, thread in all of the strands of yarn.
Conclusão
Rayme Ivers
Membro desde: 05/04/20
157 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 35
Ao todo: 3,255
