Ir para o conteúdo principal
How to repair a broken seam
O que você precisa
  1. How to repair a broken seam, Identify the damaged seam: passo 1, imagem 1 %32 How to repair a broken seam, Identify the damaged seam: passo 1, imagem 2 %32 How to repair a broken seam, Identify the damaged seam: passo 1, imagem 3 %32
    • Locate the damaged area of your item.
    • Check how it looks on the outside, and whether it is spreading further by gently pulling the seam.
    • Also check how the damage looks on the inside, and take note of the type of stitching, and fabric condition around the seam.
  2. How to repair a broken seam, Prepare & repair: passo 2, imagem 1 %32 How to repair a broken seam, Prepare & repair: passo 2, imagem 2 %32 How to repair a broken seam, Prepare & repair: passo 2, imagem 3 %32
    • Prepare and clean the area around the damaged seam by removing broken thread and trimming any loose threads.
    • Prepare the damaged seam by placing the fabric edge to edge.
    • Place the item under the sewing machine, and make a short back-and-forth lockstitch using the reverse lever, to secure one end. Then proceed to make a single long stitch along the seam until the end of the damage. Secure at the end with another locking stitch. Inspect the repair, and if it requires another long stitch, repeat the process.
    • Tip: check the iFixit basic sewing skills page for more tips on sewing machine setup.
  3. How to repair a broken seam, Finished and ready!: passo 3, imagem 1 %32 How to repair a broken seam, Finished and ready!: passo 3, imagem 2 %32 How to repair a broken seam, Finished and ready!: passo 3, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 21
Últimos 30 dias: 58
Duração total: 430
