Ir para o conteúdo principal
How to repair a broken label loop
O que você precisa
  1. How to repair a broken label loop, Locate the defect: passo 1, imagem 1 %32 How to repair a broken label loop, Locate the defect: passo 1, imagem 2 %32 How to repair a broken label loop, Locate the defect: passo 1, imagem 3 %32
    • Locate the broken tag, and find the area where it snapped off from
  2. How to repair a broken label loop, Tidy the broken area: passo 2, imagem 1 %32 How to repair a broken label loop, Tidy the broken area: passo 2, imagem 2 %32 How to repair a broken label loop, Tidy the broken area: passo 2, imagem 3 %32
    • Often the cause of the breakage, is that the sewing thread tore through the tag, leaving frayed ends
    • Trim away any damaged or frayed ends of the tag
    • Use a "seam ripper" tool, or small scissors, to carefully remove the old thread from the item
  3. How to repair a broken label loop, Re-attach the label: passo 3, imagem 1 %32 How to repair a broken label loop, Re-attach the label: passo 3, imagem 2 %32 How to repair a broken label loop, Re-attach the label: passo 3, imagem 3 %32
    • Prepare your sewing machine in a clean location, and position the item underneath the needle. Depress the foot to secure the item in place.
    • Tip: for setting up a sewing machine, use the resource Thread a Sewing Machine
    • Make a short lock stitch, and then a straight line stitch from one side of the label to the other. Make a second stitch using the reverse lever, and one final stitch in the original direction. Finish with a locking stitch
    • Remove the item from the machine.
  4. How to repair a broken label loop, Trim the repair: passo 4, imagem 1 %32 How to repair a broken label loop, Trim the repair: passo 4, imagem 2 %32 How to repair a broken label loop, Trim the repair: passo 4, imagem 3 %32
    • Carefully trim the thread on the outside...
    • ... and on the inside
    • Check the repair and pull the label gently to test the durability
  5. How to repair a broken label loop, Finished and ready!: passo 5, imagem 1 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 139
