Ir para o conteúdo principal
How to repair Yamaha rx-v673 no sound issue (not always a permanent fix)
O que você precisa
Vídeo de Apresentação
    • This is not a difficult repair but take a look at this video before you dive in as there are some details you might not be comfortable with.
Conclusão
4 outras pessoas executaram este guia.
Dan Dunham
Membro desde: 04/15/17
3.327 Reputação
Autoria de 29 guias
25 comentários
Same problem here. Tried to just reload the Firmware several times via USB… kept getting an error 010 at the end. Was a bit skeptical of above so I initially just unplugged everything from the mother board with the exception of not removing it and therefore not disconnecting it from the board on the side, and then re-assembled. Booted up and again tried to reload firmware several times via USB. Same error at end. So then I removed the board and baked at 390 for 15 minutes per the above, AFTER removing the one piece highlighted. Let it cool, reattached everything. Then tried to update the Firmware via network. It finished quickly, but still no sound. Lastly, I tried again with the USB method and SUCCESS!! Everything is working fine! very very strange… not sure which step fixed it. a) removing the board from side board (complete disconnection), b) baking, c) trying the network method first, but ITS WORKING!!! Cheers.
dbwarner5 - Responder
That's great news! And thanks for the detailed response. This is a method I have used for several computer systems that developed problems with their GPUs. I believe what is happening is that over time with the heating and cooling cycles the solder joints under the chips themselves develop faults and eventually stop conducting properly. Basically this baking process remelts the solder in the connections and allows proper contact to the GPU or CPU or whatever chip it is. So far this fix is working well for me so I hope you experience the same.
Dan Dunham -
Doing this right now, so thank you very much! Question, on removing the capacitor before baking - any tricks to get it out? Or just have to unsolder it.
kaleb - Responder
Hey Kaleb,. I missed you question but to get that cap out you'll just want to desolder it with a desoldering tool of some sort and pull it out. You could just heat the lead up and pull each side out individually but that's going to put more stress on the cap and is kinda messy.
Dan Dunham -
Hi Dan,
it's amazing if I heat the DTS component with a hair dryer and then I turn on the RX, the sound is there directly. And if I cool or that I turn it cold you have to wait between 5 and 10 minutes!
michels - Responder
That sounds about right, it seems that these chips are very unstable and you can get all sorts of strange problems from them. Mine would work for about a day or two after heating it and then it would start clicking in and out and then fail completely and would not come back. I assume Yamaha got a bad batch of chips and I have heard similar complaints about other brands as well. It's too bad TI didn't step up and pay for the repairs but that's how things go these days.
Dan Dunham -
Dan, I'm having the same issue. Did you ever come up with a fix?
Michael Estes -
I considered buying some of the replacement chips just to see if I could repair it but I made such a mess of getting the old chip off that I decided against it. With the 5 piece min. I didn't want to spend the money on it rather than a new unit with updated processing. If somebody tries it please update this thread.
Dan Dunham -
I have a RX-A730 and it started having a delay with the sound coming on. At first this was only a couple of minutes. Now it can be as long as an hour. This was true regardless of what I was using, TV/cable, DVD player, Streaming through my TV and the AV cable, streaming Net channels, and my turntable. I tried all methods of a firmware update and it would end in an error code.
From what you are describing, it looks like my unit needs to be on long enough to heat the chip. This all started around the four and a half year mark.
Cindy Shaw - Responder
If that receiver uses the same sound processing chip that mine did then you will most likely continue to see unstable performance from it. It's just a bad design. You can try and bake the board BUT since it sounds like you receiver works ok after its turned on you might just leave it on. Iddle current is not high on these so it's not like your waisting much electricity to just leave it on. You'd use more electricity trying to fix it with a board bake than just leaving it on. With that said if you are having other issues then it might be worth a try. Just remember that at the end of the day I was not able to actually fix the problem.
Dan Dunham - Responder
Mine has been loosing sound for about a month now. At first, the sound would pop on and off about 5 to 10 cycles at first power up. Every day i power it on, the delay in sound is extended. Now a month later it takes about 10 minutes to produce sound when powered on.
After reading these forums, I do beleive as the DTS chip needs to warm up before it produces sound. Maybe it needs to be baked. I may try this fix in the future as it gets worse.
Thanks for all the info…
Daphne Guilding - Responder
Just tested my RX-V673. I heated DSP chip with hair dryer and DSP started to functioning then little bit cold spray and its dead. It’s Taxas Instruments D80YK113CPTP400 failure. Source: http://media.digikey.com/PDF/PCNs/Texas%... “Description of Withdrawal/Discontinuance:
The affected products listed below will be discontinued.TI is offering a non-cancelable lifetime buy for the products listed.
Each replacement device listed below is a pin-for-pin direct functional replacement of a corresponding affected device.Please contact your local Field Sales Representative if you have any questions.
Reason for Withdrawal/Discontinuance:
Premature aging issue on the Rev B and C of this part family”
reijod - Responder
I have had the same problem of missing sound on a RX-V677 Yamaha receiver. I have heated up the DSP chip (D80YK113DPTP400) which is supposed to be the revised version per reijod’s link and the amplifier recovered its voice. I used an airgun calibrated at 150 °C which is the maximum junction temperature these chips can safely handle. I would NOT recommend to bake the whole board at a temp greater than 100 °C otherwise all the plastic parts like connectors are going to melt and the board will be damaged. I am currently trying to find a replacement HDMi board but the price is ridiculously high considering the receiver selling price. Furthermore, it is not easy to find. If someone wants to share a link, I’ll gladly take a look, thanks.
Christophe - Responder
Hi,
I have an Rx-a3020 with the same issue. However the 2nd and 3rd zone don't have the issue. Do they have separate chips or must this be a different issue?
Thanks for your reply
Best regards
Davy
Davy Rodriguez - Responder
Plus one more:-My RX-V383 suddenly stopped after about 4 year from new. Found Dan’s instructions. Removed only the peripheral case screws to remove the cover, head straight for the Texas dts chip, put the heat gun on the chip in a number of short circular small bursts, taking care not to compromise any other components. Test, and voila, it works, diagnosis correct. I know, perhaps only for a short time. Thanks Dan!
Tim2muntU - Responder
My Yamaha RX-V673 receiver is suffering from the same issues as well, and application of a heat gun to the errant chip confirms that it’s the D80YK113CPTP400  at fault. I contacted Yamaha via a tech, who said, and I quote “There is no report from HQ that this chip is affecting our products in huge quantities.” In other words, they did not acknowledge that there was a problem with receivers containing this particular chip. Note that receivers from other manufacturers that used this chip also suffered similar issues. For Pioneer receivers, Google “Pioneer U22 error”. In the Onyko/Pioneer case though, they offered free repair up until January this year.
brian - Responder
Hi to all of you. I have the same problem with rxv773 . I opened the unit and apply heat on the dts chip with heat gun in slow circular morion for 20 sec. It worked fine for a month. The chip is D80YK113CPTP4. Number above cinemaDSP logo is 21 538 PTP. I was at the store with hifi and I saw new yamaha receivers 4 series and i looked inside and i saw the same TI chip D80YK113CPTP4 but the number above cinemaDSP logo was 30 538 PTP. So could that be updated version of 21 538 chip? I would like to buy chip online and replace it but i dont know if I should buy 21 538 or 30 538? I found them on aliexpres. The serial number is the same. Anyone ?
Mirko Majky - Responder
Hi to everyone. Update on subject. I ordered new chip online D80YK113DPTP4, that is replacement chip for CPTP4. I took the board out and took it to a mobile phone service guy. He replaced the chip for me, and i put everything together. I didnt connect anything to receiver, just turn it on , selected radio, and put antena in. The speaker icons showed up in second. So I tought that i fixed my receiver. After i conected every thing , i turn it on, speaker icons show right away, but NO SOUND. Only pure direct plays radio… I did firmware update from usb, but still nothing.
Does this chip need some sort of programing or what? Before i waited few minutes and the sound was there, but now nothing. Help people.
Mirko Majky if the dsp chip is replaced the unit needs to be reprogrammed. The instructions for this are in the service manual. Let me know if you need more information.
rxsv11 - Responder
may I get that manual? Thanks.
Julian Jey -
just visit https://elektrotanya.com/keres and type in your model number (or a similar model #). mine was RX-V477
rxsv11 -
Hi, did reprograming the unit worked for you?
I’m thinking about replacing the DPD chip with the “D” version but I wanted to know if works before buying the new chip?
Frank Lima -
hi. same, same, same problem on my RX-V673
Julian Jey - Responder
Hi All, Not sure where I had read aboout this issue but I have my 2013 RX-V673 receiver back on duties since almost a year now after installing a piece of heater of those for mosquito tablets devices. It goes straight to 220V and heats enough and steady to keep the receiver working without issues. It is powered on all the time (standby or switched on). No any more problems. At least I had extended receiver life for a bit longer.
see my post here:
https://www.hometheatershack.com/threads...
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 20
Últimos 30 dias: 117
Duração total: 28,453
