Ir para o conteúdo principal
How to remove the Samsung LA40R81BD 40in LCD TV rear cover
O que você precisa
  1. How to remove the Samsung LA40R81BD 40in LCD TV rear cover, Rear Cover: passo 1, imagem 1 %32
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
Conclusão
11 outras pessoas executaram este guia.
Richdave
Membro desde: 04/09/10
32.105 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.541 guias
3 comentários
Got cover off but how to unplug the wires
cpeeledc - Responder
What size screws holds on the rear panel?
D Mack Miller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 55
Duração total: 24,148
