Introdução
This ifixit technique illustrates a step by step procedure on how to remove burnt stains from a cooking pan.
Caution: This process involves scrubbing the pan you are intending to clean after it has been heated. Make sure the pan has cooled enough after heating so you do not get burned while scrubbing. Protective gloves are recommended during this step.
O que você precisa
Prepare your workstation by making sure you have all the listed tools. Next, ensure the burnt pan is cool before starting the process. Remove any loose debris or food particles from the pan.
Sprinkle a generous amount of baking soda over the burnt areas of the pan. Use enough baking soda to cover the stains fully.
To remove stains from your cooking pan, follow these step by step instructions.
Uma outra pessoa concluiu este guia.
