Ir para o conteúdo principal
How to remove and clean the Dyson DC14 filter
O que você precisa
  1. How to remove and clean the Dyson DC14 filter, How to remove and clean the Dyson DC14 filter: passo 1, imagem 1 %32
    • The filter is located in the canister of your vacuum.
  2. How to remove and clean the Dyson DC14 filter: passo 2, imagem 1 %32 How to remove and clean the Dyson DC14 filter: passo 2, imagem 2 %32 How to remove and clean the Dyson DC14 filter: passo 2, imagem 3 %32
    • Open the canister filter compartment. Push the clip upwards, and open the canister top away from you.
    • Remove the yellow filter housing.
  3. How to remove and clean the Dyson DC14 filter: passo 3, imagem 1 %32
    • Remove the blue sponge-filter from the yellow filter housing.
    • The filter and housing must both be completely dry before reinstalling. Do not use your vacuum without filters installed.
    • Clean the blue sponge-filter in cold water until the water runs clear.
Conclusão
Once the filter is cleaned, set the blue filter sponge and the yellow filter housing aside for at least 24 hours to dry. Do not use your vacuum without a filter, or when the filter is still wet. To reassemble, follow the steps in reverse order.
17 outras pessoas executaram este guia.
Donald Percivalle
Membro desde: 10/03/12
1.923 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-22, Amido Fall 2012 Membro de Cal Poly, Team 3-22, Amido Fall 2012
CPSU-AMIDO-F12S3G22
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 29
Últimos 30 dias: 123
Duração total: 39,839
