Ir para o conteúdo principal
How to refurbish performance skateboard bearings
O que você precisa
  1. How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: passo 1, imagem 1 %32 How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: passo 1, imagem 2 %32
    • Turn your wrench to the left to remove the wheel nut.
    • Take the wheel off of your trucks by pulling.
    • Keep all nuts and spacers in separated, designated areas.
    • Wear gloves. You are working with messy materials such as gasoline.
  2. How to refurbish performance skateboard bearings: passo 2, imagem 1 %32 How to refurbish performance skateboard bearings: passo 2, imagem 2 %32
    • Firmly lever the bearing out using your screwdriver.
    • Do not be overly forceful to avoid scratching the bearing.
  3. How to refurbish performance skateboard bearings: passo 3, imagem 1 %32
    • Soak the bearing in a cup with premium gasoline for 5 minutes.
    • Soak each bearing separately so none are lost or dented.
  4. How to refurbish performance skateboard bearings: passo 4, imagem 1 %32 How to refurbish performance skateboard bearings: passo 4, imagem 2 %32 How to refurbish performance skateboard bearings: passo 4, imagem 3 %32
    • Take the bearing out of the gasoline and remove one side of the outside plastic locks by applying pressure on the inner ring and prying up.
    • Make sure you can clearly see and access the ball bearings.
  5. How to refurbish performance skateboard bearings: passo 5, imagem 1 %32
    • Use your toothbrush to clean the bearings by using a gentle back and forth scrubbing motion.
    • Rinse the bearing with water and let dry for 5 minutes.
  6. How to refurbish performance skateboard bearings: passo 6, imagem 1 %32 How to refurbish performance skateboard bearings: passo 6, imagem 2 %32
    • Once dry, pick up your bearings with two fingers and drop 2 drops of skateboard lubricant into the bearing.
    • Spin the bearings immediately to spread the lubricant evenly.
  7. How to refurbish performance skateboard bearings: passo 7, imagem 1 %32 How to refurbish performance skateboard bearings: passo 7, imagem 2 %32 How to refurbish performance skateboard bearings: passo 7, imagem 3 %32
    • Use a paper towel to remove excess lubricant.
    • Replace the plastic guard.
Conclusão
To reassemble your device, firmly put bearings back into your wheels and tighten them back down onto the trucks.
Uma outra pessoa concluiu este guia.
Luke Marshall
Membro desde: 04/09/15
126 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 30-2, Green Spring 2015 Membro de Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 5,947
