Introdução
This guide will help you patch a dry wall hole using drywall joint compound, paint scraper and a cleaning tool (I'll be using wet kitchen tissue).
O que você precisa
Clean up the area you want to patch with a wet soft cloth. Pat it dry.
Paint can be used after the compound has dried off to match your door's finish. There are guides available online to help you paint over the drywall compound.
