Ir para o conteúdo principal
How to override the fast fan caused by an Incompatible Drive
O que você precisa
  1. How to override the fast fan caused by an Incompatible Drive, How to override the fast fan caused by an Incompatible Drive: passo 1, imagem 1 %32 How to override the fast fan caused by an Incompatible Drive, How to override the fast fan caused by an Incompatible Drive: passo 1, imagem 2 %32 How to override the fast fan caused by an Incompatible Drive, How to override the fast fan caused by an Incompatible Drive: passo 1, imagem 3 %32
    • Pretty simple guide here . UNSCREW the logic board PCB from the ORIGINAL hard drive from the iMac 2009/2010/2011+ Hard dive for step 1:
  2. How to override the fast fan caused by an Incompatible Drive: passo 2, imagem 1 %32 How to override the fast fan caused by an Incompatible Drive: passo 2, imagem 2 %32 How to override the fast fan caused by an Incompatible Drive: passo 2, imagem 3 %32
    • Step 2: is simple. Simply put clear tape or anti static tape on the logic board PCB of the original hard from the iMac . Making sure it wont touch anything, as safety.
    • MAKE SURE YOU PLUG IN only the temperature sensor cable FROM the iMac to the hard drive Logic board we have taped to the iMacs back housing, this is *crucial. This will make the iMac control the fan speed as normal. :)
  3. How to override the fast fan caused by an Incompatible Drive: passo 3, imagem 1 %32 How to override the fast fan caused by an Incompatible Drive: passo 3, imagem 2 %32
    • and thats it !
    • install hard drive, there is just enough space. Enjoy
Conclusão
8 outras pessoas executaram este guia.
codahyder
Membro desde: 06/28/15
257 Reputação
Autoria de 1 guia
3 comentários
Hi! So sorry about that. I did not put in the exact corresponding models which will work with this exact guide (only models WITH temp sensor cable apply* here). Thanks so much for checking it out! I made this a while back, sort of to keep what I had done in archive and to *possibly* help others. For one software fix* I have used a program for Mac called "SSD Fan Control" and it does wonders. For a permanent fix I am not so sure/ there may be kits available through some 3RD party mac stores . Possibly even here ?! That help reroute the internal temp sensor models. Again apologies and best of luck to anyone trying to figure this out. haha :)
Lost account - Responder
I use HDD Fan Control. It uses the temperature read by S.M.A.R.T in the replacement drive. http://www.hddfancontrol.com/
steve - Responder
Can somebody explain how the apple control system works exactly? Why is the above mentioned fix really safe?
Wulf Brandes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 73
Duração total: 8,841
