Ir para o conteúdo principal
How to open the TicWatchPro
O que você precisa
  1. How to open the TicWatchPro, Unfasten the screws: passo 1, imagem 1 %32
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
  2. How to open the TicWatchPro, Open the watch: passo 2, imagem 1 %32 How to open the TicWatchPro, Open the watch: passo 2, imagem 2 %32
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
  3. How to open the TicWatchPro, Disconnect the sensor cable: passo 3, imagem 1 %32 How to open the TicWatchPro, Disconnect the sensor cable: passo 3, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
  4. How to open the TicWatchPro, Remove the back cover: passo 4, imagem 1 %32
    • Remove the back cover.
Conclusão
Repair didn’t go as planned? Check out our Answers community for help.
Dominik Schnabelrauch
Membro desde: 11/23/16
247.305 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.740 guias
2Comentários do guia
T w lte 4G. Botón power como cambiar no conecta
yo tuve - Responder
Mostrar tutorial (si existe). gracias
yo tuve - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 2,003
