Ir para o conteúdo principal
How to open and close a Metabo St EP 455
O que você precisa
  1. How to open and close a Metabo St EP 455, loosen the cover: passo 1, imagem 1 %32 How to open and close a Metabo St EP 455, loosen the cover: passo 1, imagem 2 %32
    • Make sure the jigsaw is unplugged.
    • Unscrew the bolt holding the guide plate to the jigsaw.
    • Unscrew the 10 screws holding the 2 frame halves together.
  2. How to open and close a Metabo St EP 455, separate the 2 halves: passo 2, imagem 1 %32 How to open and close a Metabo St EP 455, separate the 2 halves: passo 2, imagem 2 %32
    • Separate the 2 halves by slowly prying them apart, going around the edges evenly.
    • When separated, take care of some loose parts.
    • The nut holding the guide plate bolt.
    • Piece of plastic holding some cables.
    • Metal strip pushing the blade back.
  3. How to open and close a Metabo St EP 455, prepare to put the halves together: passo 3, imagem 1 %32 How to open and close a Metabo St EP 455, prepare to put the halves together: passo 3, imagem 2 %32
    • Regardless of how the halves are separated, to put them back together, it is practical to put the saw blade mechanism in the halve with the rest of the parts.
    • Then, make sure the right parts line up and are fitted correctly:
    • The holes for the blade holder. The axis is located on the other halve.
    • The blade driver.
    • The blade guide.
    • The metal strip.
  4. How to open and close a Metabo St EP 455, close it: passo 4, imagem 1 %32
    • Now, add the empty halve on top of the halve containing the parts.
    • Screw everything back together.
Linha de Chegada
knipwim
Membro desde: 09/01/18
8.685 Reputação
Autoria de 31 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 39
Duração total: 1,558
