Introdução
This guide provides detailed instructions to disassemble your multimeter, allowing you to access internal components for maintenance or repair purposes.
O que você precisa
Place the multimeter on its front.
Flip up the kickstand.
Use a PH1 screwdriver to unscrew the single screw holding the battery cover and kickstand.
Remove the battery cover and kickstand.
Remove the batteries, if present.
Use a PH1 screwdriver to unscrew the four screws holding the back cover.
Insert a pick into the top gap between the backshell and front cover.
Partly leverage the front cover away from the backshell.
Insert a pick into the bottom gap between the backshell and front cover.
Fully leverage the front cover out of the backshell.
