Ir para o conteúdo principal
How to open a bObsweep Robotic Vacuum for Repair
O que você precisa
  1. How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: passo 1, imagem 1 %32 How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: passo 1, imagem 2 %32 How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: passo 1, imagem 3 %32
    • Flip Bob over and remove the 7 screws around which hold the cover together.
    • Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
    • Depending on your model, there may be only 6 screws installed on bObsweep.
  2. How to open a bObsweep Robotic Vacuum for Repair: passo 2, imagem 1 %32 How to open a bObsweep Robotic Vacuum for Repair: passo 2, imagem 2 %32 How to open a bObsweep Robotic Vacuum for Repair: passo 2, imagem 3 %32
    • There are two screw holes inside the brush compartment: one in the centre, one on the left end. Remove both and keep aside for reassembly.
    • There are five more screws around bObsweep's edges. Two are installed at the top and bottom, and one on the right end of the main brush.
  3. How to open a bObsweep Robotic Vacuum for Repair: passo 3, imagem 1 %32 How to open a bObsweep Robotic Vacuum for Repair: passo 3, imagem 2 %32
    • Flip bOb back over so you can see the screen. Lift the cover up to reveal bObsweep’s main board.
    • Detach the power inlet from the cover. Grip and slide it out.
  4. How to open a bObsweep Robotic Vacuum for Repair: passo 4, imagem 1 %32 How to open a bObsweep Robotic Vacuum for Repair: passo 4, imagem 2 %32
    • Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
    • 1. On the bottom left corner: a small connector with red, black and white wires.
    • 2. One thick white wire that attaches on the right side of the previous connector.
    • 3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
    • Place the cover aside and begin your repair.
Conclusão
To reassemble your bObsweep, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Tatiana
Membro desde: 06/28/14
737 Reputação
17 Guias de autoria
Um comentário
Change battery, and still does what it did before. Battery life is one bar only, and the moment u push start it shuts right off. Even after charging all day. Please help
Gerqui Vila - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 2,653
