Ir para o conteúdo principal
How to manually Unload Filament on an Ender 3 Pro
  1. How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: passo 1, imagem 1 %32 How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: passo 1, imagem 2 %32 How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: passo 1, imagem 3 %32
    • Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
    • Navigate to Temperature > Nozzle.
    • Adjust the nozzle temperature by turning the knob and confirm by pressing it.
    • Use whatever temperature you would be printing with, minus about 10°C. For both PLA and PETG 210°C usually works fine.
  2. How to manually Unload Filament on an Ender 3 Pro, Wait for the hotend to heat up: passo 2, imagem 1 %32
    • Wait until the current temperature (bottom) matches the target temperature (top).
  3. How to manually Unload Filament on an Ender 3 Pro, Pull the filament: passo 3, imagem 1 %32
    • Press down on the extruder lever arm and pull out the loaded filament.
    • Fully pressing down the lever arm might lead to the filament snagging when you try to pull it out. Just pressing it a bit will usually suffice.
  4. How to manually Unload Filament on an Ender 3 Pro, Set cooldown: passo 4, imagem 1 %32
    • Navigate to Temperature and press Cooldown.
    • If you do not have the Cooldown-option available, you can just repeat step one and set the temperature to 0°C instead.
Conclusão
This guide also applies to loading filament. You just need to push in the filament instead of pulling it out.
Uma outra pessoa concluiu este guia.
Sebastian
Membro desde: 08/19/18
31.055 Reputação
Autoria de 71 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 58
Ao todo: 2,029
